SailNet Community - View Single Post - Irwin - Bluewater Capable???
post #16 of Old 03-05-2008
bob chaisson
Wharf Rat
bob chaisson's Avatar
They came a long way between 1971 and 1988. Bulkheads and cabinets are all teak hardwood (teak marine plywood), Yanmar 3GM30 engine, Shure pump water pressure, good size icebox w/4" insulation. Fixed almost all the leaks (most at thru deck hardward - typical for a 20 yr old boat) and the hull deck joint has a full overlap with wood reinforcement rails and thru bolted. I have located most of the equipment used on the boat in the aftermarket and it is pretty much mainstream equipment with a smattering of some better quality stuff. When I made my Vang, I brought it to the local rigger for splicing the fiddle. When I told her what boat it was for, she said the Irwin Rig was very robust and I should consider stepping it up one size to match. I wouldn't think twice of sailing her anywhere after I tweak her a bit.
bob chaisson is offline
