SailNet Community - View Single Post - Charging problem
post #2 of Old 03-05-2008
theartfuldodger
theartfuldodger's Avatar
Send a message via Skype™ to theartfuldodger
check field plug if you can and be sure there is power on one of the two wires, have had trouble myself in this area, and have since change the design to correct the heat problem. You should be able to full field the alternator and check its out put as well, Balmar's website should show you how to do it.
Brake Free
Lake Ontario
42 CC Passage
theartfuldodger is offline
