SailNet Community - View Single Post - How effective is a solar panel MPP tracker?
post #7 of Old 03-07-2008
tomaz_423
tomaz_423's Avatar
OK, I found this number in the link above:
"Power Conversion Efficiency Typical 98% at 60 amps with a 48 V battery and nominal 48 V solar array"
This is better then I expected. Of course conversion of 48 V is more effective then conversion of 17 V, but still - it is good.
I also found that: MPPT Solar Charge Controllers
Most modern MPPT's are around 92-97% efficient in the conversion
I was expecting at least 4 to 5% loos at 17V and perhaps 1,5 to 2% at 48V.
My logic was based on the old knowledge: whenever you do a solid state conversion you may expect a voltage drop of around 0,7V. This was true for Silicon transistors and chips, but technology must have moved forward.
So, if you only loos a few percent on a conversation this is great. You probably loose more on the wires.
Beneteau Oceanis 473
finished cruising after two years.
tomaz_423 is offline
