SailNet Community - View Single Post - Black Mold
Thread: Black Mold
post #2 of Old 03-09-2008
sailingdog
Chlorine bleach is fine for cleaning off the mold, provided you rinse it with water afterwards. Fiberglass is generally not harmed by bleach, and many new bath enclosures are fiberglass. Lysol or something similiar might also be a good idea. I don't know if I'd use Kilz primer over the fiberglass though. Last year a new product was introduced which was a spray that was designed to be used as a preventative measure against surface mold.
However, none of these measures will help unless you take steps to eliminate the cause of the mold forming. Usually it is either a leak or inadequate ventilation.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
