Originally Posted by chucklesR
Jeff is correct of course, but they sure do look pretty when they splash around before they sink.
Just enough overhang so the anchor doesn't hit the bow going up or coming down. More than that and it's like a pot belly on a 50 year old. Saddly overdone and past it's prime.
However, one thing not really capitalized on about the overhangs... the anchor is one issue it solves - but it also extends out the Jib or Genoa and allowing for greater sail area... depending on course that it is rigged as such to utilize (most are)... in which case - beyond the drawback that overhang for marina billing uses is used against... can be an asset..................
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
