SailNet Community - View Single Post - Masts and Paint
Thread: Masts and Paint
post #6 of Old 03-15-2008
sailingdog
Edo-
Remove the fittings that you can and paint under them, since that will give the paint the best chance of staying on the mast, and will allow you to inspect the fasteners and holes for corrosion and re-bed them with TefGel or LocTite (blue) as needed.
To scuff the exisiting paint, use a 120 grit sand paper, and sand it just enough to remove the gloss from the surface. Wash the surface well before you start sanding so you don't embed wax, oil or other surface contaminants when you sand.
To keep a wet edge refers to only painting an area small enough that the edge of it will still be wet when you move over to cover the next area. This is so the paint flows better and will hide the different sections and allow their edges to blend into each other.
Many masts are painted using a two-part LPU paint like Awlcraft. This gives a very durable and long-lived finish.
sailingdog is offline
