Thread: Keel Fairing
Old 03-18-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
You can use thickened epoxy. Don't use the colloidial silica or microballon filler. I'd recommend using the chopped fiberglass filler. Sand through the gelcoat and apply the thickened epoxy to the fiberglass. After it cures, wash it down with water and a scotchbrite pad to remove the amine blush, sand it fair, and then apply the barrier coat.
One question—is the grey and red/brown coloration remaining bottom paint??? If so, then the guy did a really lousy job. If it bottom paint, you'll need to remove it all, down to the gelcoat. BTW, it looks like there is some crazing or alligatoring of the paint or surface. Is that in the gelcoat or just in the remaining paint??
If you're new to the Sailnet Forums... please read this POST.
