  #11 (permalink)
Old 03-19-2008
halekai36's Avatar
halekai36 halekai36 is offline
halekai36 has a spectacular aura abouthalekai36 has a spectacular aura abouthalekai36 has a spectacular aura about
Halekai-
Unfortunately, using a moisture meter properly is a bit of an artform, and there are a lot of things that can throw it off. If the boat was recently hauled out, the hull will show a relatively high, but usually misleading, moisture content. If there is water in the bilge, it may also throw the meter off.
That's why I was very careful to say things like;
"With your own moisture meter, and some studying, about proper use"
and
"TRUST me it will pay for itself during the first use if used properly."
Art form? Now that's a bit of a stretch.. Gelcoat repair and Awlgrip work is an art form learning how to use a moisture meter requires common sense and a bit of a learning curve but not a practiced skill that takes years to learn to do properly. I certainly don't consider it rocket science just common sense and a bit of learning.. I've saved thousands of dollars over the years by owning and knowing how to properly use my own moisture meter.
BTW the meter Holland sells is the identical meter to the one I own except I got HOSED on mine. At the time I did not know about Holland Marine Products... Wish I did..!!
With the above said I'm going to inject a little opinion garnered in 35 year's of boating and over 25 owned boats. Oops make that 25+/- as I just bought another boat on Monday.. Someone commit me!! If you don't agree, fine, but do take the time to read it because it CAN save you money even though it seems counter intuitive..
Here it goes;
All boats are bottomless pits but a fixer upper is NO DEAL! Trust me on this one. Many of the other long timers on here will also agree. Spending a little more on a boat in good to pristine condition pays off in the long run in more ways than one!
My buddy & first time "big boat" owner knew everything and refused to take mine or other friends advice. We tried to talk him into a very, very nice, & exceptionally well maintained, 1988 Catalina 30 for a 30k asking price (read; bargain). When all was said and done he ignored our advice and chose the 17k asking 15k buy 1980 Catalina 30 (read; piece of crap).
The end of the story, even now, is nowhere in site and at this point, 20+ months later, he now has, at last count, 37k invested in a boat still worth, on a good day, 19-20k at best!
Here's what he's had to do so far: New furler, new sails, new interior cushions, new running rigging, new bulkhead, new spreaders, new steering cable & chain, new keel bolts, new exhaust hose, removed the wooden laminate in the keel stub & re-glassed it, new exhaust manifold & elbow, new water pump, new batteries, new wiring, new head, new plumbing, new running lights & mast wiring, etc. etc. and on and on. He's still facing an engine rebuild, at minimum, and about 30% of the deck needs to be re-cored. By the time he finishes he will have well over 45k maybe 50k into a 19-20k boat, on a good day, and he's done 90% of this work himself...
Cheap boats are NO DEAL even if you do ALL the work your self. A SURVEY IS A MUST !!!!!!!
After 30+ years and 25+ boats, I now only buy 1 PERCENTERS. A 1% boat is that needle in a haystack boat that is in absolutely pristine condition with maintenance, upkeep and upgrades done only with the best materials and care for quality. These boats are hard to find but they do pop up. You'll at least want a boat in the top 15%, condition wise, or it's going to cost you.
The devil is in the details. This is one of the drawers in the v-berth of our 1979 1 percenter. No mold, no scratches, no discoloration of the wood no drips, runs or sags in the varnish. The P.O. of our boat knew boats and boating so he finish sanded each of the boats drawers inside and out then varnished them to prevent & minimize mold, mildew and moisture absorbtion. A 1% is a boat that has been finished well above and beyond factory standards.... Did I mention that this boat is a 1979!!!! and this photo was taken in 2007. You get what you pay for especially with boats.
Take this advice or leave it but the gain from buying a top condition boat up front saves you in lots of areas! You may pay 10-20% more, up front, for the identical boat (vintage wise) in pristine condition but that 10-20% pays you back HUGE !!! Trust me you'll never get the cheapest worst condition example of a particular model to the same condition as the finest example on the market with a 10-20% upgrade budget even if you do all the work your self..
Just my .02...
______
-Maine Sail
Casco Bay, ME
Boat - CS-36T
Maine Coast Sailing Photography
