Thread: Keel Fairing
  #18 (permalink)
Old 03-20-2008
KeelHaulin's Avatar
KeelHaulin KeelHaulin is offline
STARBOARD!!
KeelHaulin will become famous soon enough
You guys crack me up... IIRC "Bondo" is vinylester that has some fillers in it that makes it more workable/shapeable. If you added chopped glass to it it would probably be equivalent to the strand-mat layers of your hull as most hulls are vinylester resin. I still prefer the epoxy with fillers; easy to mix/use and has better adhesion properties.
You can avoid lots of prep work (and lead dust exposure) by not removing the existing paint from the keel; that was why I mentioned not sanding off all the existing paint.
