single line reefing?
Sounds interesting, but I''m still trying to picture the set-up (its been a long week).
Do you have any manufacturers part #''s or pictures of the stainless steel rod connector shaped like a U? What size and type of blocks do you use? Even better do you have pictures of the set up?
Correct me if I''m wrong, ''you still have to go forward to the mast to tighten and adjust the tack of your reef''? And am I to understand that this set-up is the same that is being used as a cunningham adjuster?
