SailNet Community - View Single Post - La Paz to Puerto Vallarta
post #5 of Old 03-20-2008
ianhlnd
A little less cheek
ianhlnd's Avatar
That would work too, but Los Frailes would be closer. The problem with Mztlan to PV is usually benign weather, so expect to motor most of the way. Right now the wind is from the south here in Mztlan, remember it varies throughout the day, whereas if you run from Muertos or Los Frailes, you should be able to sail most of the way, the wind in the sea is generally pretty constant.
Just checking in.
Where ya'll keep'n the wimmin 'round here?
ianhlnd is offline
