SailNet Community - View Single Post - tohatsu 3.5 won't run without choking
post #20 of Old 03-22-2008
NautiG
NautiG's Avatar
Running the engine dry (ie disconnecting the fuel line, or shutting off the fuel valve) would also probably help in preventing the carb from getting clogged. I have a couple two cycle engines, and I try to shut them off by cutting off the fuel supply, instead of turning the on/off switch. Especially if I know the engine is going to sit awhile without use.
Scott
Gemini Catamaran Split Decision
Captain's Blog
NautiG is offline
