SailNet Community - View Single Post - Reefing without reefing points
post #7 of Old 03-24-2008
paulk
paulk's Avatar
Just to be certain, are we talking about a sail that has no apparent provision for reefing built into it; i.e. no reef cringles (grommets) on the leech or luff, and no reef points (ties) in the sail either? Such a sail could be reefed with a roller-furler boom. If you've bought the boat used, the reefing handle you'd need to turn the boom may have been lost overboard, or lost at the bottom of a bosn's drawer or bucket somewhere on board. Have someone who knows give it a look, or post us picture here of the boom gooseneck. We should be able to tell from that if it's a roller-furler boom. If it isn't a roller-furler boom and it doesn't have any provision for reefing in the sail, you may want to have your sailmaker add some. This depends a bit on the size of the boat, however, and how you use it. Our Soling (27') had no provision for reefing the sails whatsoever. When it blew harder we let the sail flog when we had to and hiked more. If the sail has cringles but no ties, it is set up for jiffy or slab reefing. There are many books and articles that describe how that works. Once the sail has been drawn tight, you don't really need to tie it off further - it's just cosmetic, so the ties aren't really necessary. Sometimes there are grommets set in the sail without the reef-points (ties) In that case you can reeve a line through the holes and around the boom to hold the loose sailcloth from flapping, but again, it's just a question of what you prefer.
paulk is offline
