SailNet Community - View Single Post - Yamaha 9.9 help need
post #2 of Old 05-26-2003
jparker11
nauticalrich,
Yamahas always start!! Verify the spark by pulling a plug and grounding it and pulling the starter rope.
No spark, check the kill switch and make sure you DO NOT have conductivity across the two poles.
Once spark is verified, move on to fuel. I don''t know if you have an automatic choke (Absence of a choke knob), but mine doesn''t seem to work. I defeat it by putting the gear selector in forward and giving two or three full throttle pumps. Return the gear selector to Nuetral and try starting. This uses the accelerator pump to enrich the mix at cold start.
Still stubborn, move on to the fine mesh fuel filter located on the fuel pump.
Also, did you close the fuel sump drain?
Out of suggestions without the manual!!
Good Luck,
jparker11 is offline
