Old 03-26-2008
sailaway21 sailaway21 is offline
Owner, Green Bay Packers
sailaway21 is a jewel in the roughsailaway21 is a jewel in the roughsailaway21 is a jewel in the roughsailaway21 is a jewel in the rough
Good article.
If I had to add anything to it or subsequent articles it would be a reference to what used to be called the General Prudential Rule, now covered under Responsibility, along with an emphasis on the nature of special circumstances where a departure from the Rules may be necessary. Most recreational boaters, even with knowledge of the Rules, do not know that more than two vessels involvement may make the case one of special circumstances for which the Rules do not apply. Perceiving one's self as the stand-on vessel in special circumstances can have consequences unforeseen.
I think that you mentioned that the Rules only apply to vessel's within sight of one another. If not, you should.
The only other topic I'd have you expand on is the requirement for action when in-extremis. In-extremis is defined as when the actions of the give-way vessel alone are insufficient to avoid collision. And the stand-on vessel is then required to take action as to best avoid collision.
Fine work, Yamsailor.
The brain is merely a knot that keeps the spinal cord from unraveling.
