Old 03-26-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
If you're a speed freak for performance under sail... ditch the Macgregor 26. Most Macgregors have pretty pathetic sailing performance due to the compromises made to have it be a decent power boat.
Personally, if I were you and looking to get a first sailboat and as competitive as you seem to indicate you are, I'd recommend getting a boat that is raced at a club level more. AFAIK, none of the boats you've listed is raced much, and none are all that good in terms of performance. Of them, the First 235, if it is a Bendytoy First 235 might be a good choice.
It would help if you said where you would be sailing this boat...since different waters will often have different requirements.
The Cal 21 or 25 would be a much better choice. The Cal 25 isn't really a trailerable boat however, so would probably be happiest in a marina slip.
If you're new to the Sailnet Forums... please read this POST.
