Old 03-26-2008
eherlihy's Avatar
eherlihy eherlihy is offline
Will work to sail. :-)
eherlihy will become famous soon enough
Originally Posted by JohnRPollard View Post
eherlihy,
... but if you decide to purchase this boat, it might be worthwhile to let the owner re-commission it. Yes, take a good look at it while it's out of the water, but let the owner do the work to get it back in sailing trim. Otherwise you are stuck having to get the act together before you even can do a sea-trial.
ABSOLUTELY! Any offer that I make would be contingent on the boat being relaunched, and passing a sea trial with a genuine surveyor.
As for the engine Yup, I plan to check both the engine and transmission oil, and the belts, and look for a spare impeller.
Also, I will give an overall look at the interior plumbing for cracked / broken hoses, and to see that there is antifreeze in the system.
Thanks already!
USCG Licensed OUPV Captain, ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
