Old 03-27-2008
maccauley123's Avatar
maccauley123 maccauley123 is offline
SailAway
maccauley123 is on a distinguished road
If I am going to sail with just a single sail up I choose depending on where the wind is.
If sailing upwind I will use just the main. Tacking is really easy since it is essentially self tending and I can point pretty high into the wind with my boat. I have tried upwind with just the jib and while it worked the wind pushed the bow downwind pretty bad. I also found tacking was much harder due to this effect, took longer to recover from the turn and get on the new tack.
If sailing downwind and there is enough consistent wind to keep the sail filled will just use the jib.
I have seen this discussed a few times and the consensus seems to be there is no damage that can be done to the rig. The biggest consideration is what gives the most efficient performance.
You will regret the things you did not do, more than the things you did.
Get out there!
Saco Bay, Maine
1971 Ericson 29
