Old 03-31-2008
danielgoldberg's Avatar
danielgoldberg danielgoldberg is offline
danielgoldberg is on a distinguished road
Had our hull surveyed today
Our insurance company requires this to get a rider for a trip to Bermuda.
Miracle's a 1988 Freedom 45, hull number 2. Like all Freedoms and many TPI boats, she's cored.
Survey came back totally solid. No delamination, or core wetness. Slight moisture in the rudder, but who hasn't had that problem. I was confident this was the case due to a few things we've done to her. Among other things, we pulled all the through hulls 4 years ago. At that time we routed out the coring around all through hull penetrations and backfilled with epoxy. The core was entirely dry around all the through hulls then, except for one which was damp, not rotten. I was surprised that the through hull penetrations hadn't been routed/backfilled at the factory, and was told by the builder that I shouldn't forget mine was hull number 2 and it was 1988. Apparently later hull numbers had this done at the factory, as well as vacuum bagging and all the usual assortment of building/construction advances.
Anyway, just adding to the core/non-core debate. This is our first cored hull, and it was something that made me a bit wary when we bought her, but having had her for a while now, it's like anything else. Some positives and some negatives, and it's just something that we need to be aware of and check periodically. We've taken core samples from time to time from various spots, and never found anything remotely troublesome. Miracle's now 20 years old and no signs of core trouble yet. I probably just jinxed myself and the whole thing will turn to mush in 6 weeks.
Dan Goldberg
www.bermudacruisingrally.com
