  #14 (permalink)
Old 04-01-2008
sailingdog sailingdog is offline
Most water-lift mufflers will fill up with water and then flood the engine through an exhaust valve if you crank the engine for an extended period of time. If you have to crank the engine for an extended period of time, you really should close the raw water intake seacock for the water lift muffler. JUST DON'T FORGET TO OPEN IT once the engine is running.
