Old 04-02-2008
Sailormann Sailormann is offline
Here .. Pull this
Sailormann will become famous soon enough
Thanks Sailormann for the information. I am aware the correct terminology for this situation is a "leak" and felt no reason to even state the term. The water access hole is at the very bottom of the keel bolt access well and not accessible to see into even with a flashlight and mirror. I have checked the Hunter Manual and have contacted Hunter to no avail and not even a reply. Thus I came to this forum for other potential sources of information. You have given me information which has given me another idea to investigate however.
Thanks
You're welcome Sorry for being a bit sarcastic there but your post was so innocently couched that I couldn't help myself.
Anyway - before you do anything - have you ruled out the possibility that this is a limber hole ??
Limber Holes- Openings through frames to permit water to drain to the lowest part of the bilge.
