Originally Posted by Plumper
I see what you are trying to achieve. You are probably going to have to make a new continuous line to control the sock because the one that is on their will not likely be long enough. When you make it just put a double block on before you splice it. That will solve everything and probably be cheaper to boot.
Yup, except that it's already made. We had the control
line made extra long for the purpose, but didn't think to have it made with the double block on it (and neither did our sailmaker). If I can't find a double snatch block, I'll either use two singles, or have the control
line cut and respliced around a traditional double block attached to a swivel snap
shackle.
