Old 04-06-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Many rudders are fiberglass around a steel or aluminum stock with a "web" framework that is welded to the stock and that the fiberglass is laminated over. A big problem on many rudders is that they aren't sealed properly and water gets in and causes the rudder stock or webbing to corrode and fail.
Most fiberglass rudders aren't solid fiberglass, but foam or wood cored, and you need to know if the core is delaminating or rotting before you try to repair the rudder. If it is, then repairing the rudder is probably a waste of time and materials unless you re-build it completely.
If you're new to the Sailnet Forums... please read this POST.
