SailNet Community - View Single Post - Cruising Spinnakers (Symmetrical or Asymmetrical)
Old 06-24-2003
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
How close to the wind that you can sail with a spinnaker very much depends on the design of the spinnaker, both Symmetrical or Asymmetrical. Racers will often have flat cut chutes that can be carried with the apparent wind quite far forward of abeam. Typical downwind chutes are cut much fuller and while they can be carried with the wind forward of the beam, they are generally less efficient than a genoa in those conditions, especially if there is any wind at all. Cruising assymetrical chutes are generally very full cut and really do pretty poorly once the apparent wind approaches a beam reach even though they appear to be usable at closer angles.
