Old 06-27-2003
Jeff_H's Avatar
Jeff_H Jeff_H is online now
Administrator
Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about
what the numbers say? (long)
This is complex because the numbers do not tell you as much as you would think. SA/D tells you that the Holland will probably be a better light air boat than the Brewer, and the L/D''s suggest the same but both boats are moderate displacement for their waterline lengths. 186 is just not that light with very competent and comfortable modern cruisers with D/Ls as low as 160.
The motion comfort and capsize ratios really tell you less than zip about either the likely comfort or the likeliness of a capsize. The Motion Comfort Index nor the Capsize Ratio do not include hardly any of the key factors affecting comfort or capsizing such as vertical center of gravity, weight distribution, bouyancy distribution, waterline beam, cross sectional properties, profile characteristics etc. that really control the motion of a boat or its likelihood to capsize. Both are surrogate formulas that are at best marginally useful in comparing nearly identical boats.
Back to the problem at hand. The Holland is likely to be an IOR based hull and rig form. The Holland would certainly offer better performance and provide a better choice to learn to develop sailing skills. The Holland would be easier to sail short handed and would make a better daysailer. The Holland has a higher ballast to displacement and an equal draft so is likely to be able to stand to a bigger sail plan, which when combined with its more easily driven hull may be easier to sail in a blow. That said, the Holland is not likely to be a very good offshore boat, not because of its numbers, i.e. light weight, but because of its IOR hull form and weight distribution.
By the same token the Brewer is likely to be slow and not a terribly well suited to developing sailing skills and daysailing but potentially might be the better offshore boat.
Of course these are comparatively broad generalities but it is next to imposible to be more specific without actually the actual models.
