SailNet Community - View Single Post - Low Oil Pressure buzzer/alarm
post #8 of Old 04-14-2008
US27inKS
Midwest Puddle Pirate
US27inKS's Avatar
Sapadini.
Did you perhaps wire the alarm in series with the light instead of in parallel with it? If it's in series, the light will work but be a little dim and the alarm will not work. It does this because the current flow is limited by the item that uses the least current. That doesn't leave enough current to operate the buzzer. Wire them in parallel and the circuit will flow enough current for both devices, assuming that you have enough current available from the fuse and the switch will flow enough current for the ground.
John USYacht 27 "Cora Lee"
US27inKS is offline
