SailNet Community - View Single Post - Adler Barbour maintenance
post #3 of Old 04-16-2008
camaraderie
moderate?
camaraderie's Avatar
On older Adler Barbour units there is a white plastic Terminal Block where all the external wiring enters the unit. These are screw down terminals and somtimes a wire comes loose. There is also at least one fuse assembly to check there as well to see if a fuse blew. If you see any eveidence of blackening/melting at the terminals...wait for a pro...but you may save a few bucks if you check these simple things first. Good luck!
camaraderie is offline
