My guess is the handle on the side adjust the tension on a brake band or something similar... and either the band is slipping, from dirt, grease, etc.. or the band is broken. Opening up the beast will tell you either way, and it might be a relatively simple fix—like cleaning and adjusting the inner bits...
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
