SailNet Community - View Single Post - the correct prop.
post #2 of Old 04-21-2008
Faster
Have you had a recent haulout/clean? That can make a big difference if the hull and prop are not clean.
What rpm are you running at? If the engine starts pushing black smoke when you try get max rpm, it (the prop) may be too "square" and a re-pitch to 12x10 or 11 may work better for you.
Presumably this set up has been satisfactory in the past....
Faster is online now
