  #38 (permalink)
Old 04-21-2008
Maine Sail's Avatar
Maine Sail Maine Sail is offline
Originally Posted by SVAuspicious View Post
Thank you Halekai.
What would you do differently in your approach when tackling a boat in the water?
Take some Aleve or pay someone!!!!
Seriously, I have done a lot of work in water and it's NOT fun. The key is to manipulate the boat so it's the right distance away from you for each section you work. Unfortunately this requires re-tying the boat for each section.. You lay on the finger pier on your side and buff that way with your arms over head and towards the hull.
You need to be very careful NOT to hit the water with the pad as salt water makes a big mess of a compounding or waxing job. If you are in the water buff to the top of the boot stripe as this will give you a visual reference point for the pad.
Also, plug into a GFI outlet and keep the buffer cord taught and tensioned with a bungee cord. This will prevent it from slipping into the water as you move it up and down the hull. I also always wrap the plug receptacles between the buffer and extension cord with 3M waterproof electricians tape just in case.
If you do get salt on the hull rinse it with fresh water and continue on. If you salt the pad you need to rinse it thoroughly with fresh water and spin it off to dry it, on the highest setting, inside a bucket..
Remember it's never a bad thing to have your pad damp when you start. Lubrication is good!!
______
-Maine Sail / CS-36T
