Old 04-24-2008
KeelHaulin's Avatar
KeelHaulin KeelHaulin is offline
STARBOARD!!
KeelHaulin will become famous soon enough
Again; nice writup Giulietta. I was wondering about the difference between rake and pre-bend. When you measure pre-bend is that in addition to the rake? So first you measure the rake and then you put additional pre-bend on the mast?
I also have a question regarding the wedging at the cabin roof for a keel stepped mast. "Spartite" was installed at the partners so I can't remove and replace wedges. Can I add rake and bend with the Spartite in place or would trying to rake the mast at this point only result in bending? The mast already has a factory taper and pre-bend IIRC; it's a tall rig, the I is 52'. Visually I don't see much rake; but there is bend above the upper spreaders.
