I don't have a solution for you, but I'm hoping someone else does. I have the same problem with my keel steped mast. I'm trying to figure out a way to dampen the noise with mast still up. The only thing I think might help is to pull some tension on the wires from the top and then secure in place. With light tension on the wires they are going to be less likely to flop around inside the mast.
"I won't insult your intelligence by suggesting that you really believe what you just said.”
-William F. Buckley, Jr.
