The 3M
Originally Posted by sail268
If I'm applying Finesse-it what pad should I be using? Thanks for all the advice.
I've used the 3M 05725 or 05735 (same pad but with rounded edges) foam perfect it pads quite a bit and they work very well for polishing. This is not a pad you want to use for compounding though as it's a polishing grade pad.
3M #05725 Perfect-It Polishing Pad
The two foam pads in the middle are #05725's and the yellow wool pad laying in front of them is also a polishing grade pad. With wool yellow usually denotes polishing and white cutting or compounding.. You'll also need a hook and loop backing plate as the foam pads are hook and loop only..
______
-Maine Sail / CS-36T
