SailNet Community - View Single Post - Adjusting Your Rig
  #22 (permalink)
Old 04-27-2008
KeelHaulin's Avatar
KeelHaulin KeelHaulin is offline
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
Originally Posted by xuraax View Post
From the web, Young's Modulus for 1x19 wire rope is 107.5 kN/mm^2.
Using the table of breaking loads for different diameters of AISI-316 wire rope as given in the book "Principles of Yacht Design" I got the following table for wire stretch for a 2000mm wire loaded to 5% of breaking load:
diameter(mm)____breaking strength(kN)___delta L(mm)
3_______________7.7__________________1.01
4______________13.8__________________1.02
5______________21.6__________________1.02
6______________30.o__________________0.99
7______________40.9__________________0.99
8______________53.5__________________0.99
10_____________69.1__________________0.82
11_____________83.5__________________0.82
12____________120.2__________________0.99
14____________160.1__________________0.97
This practically confirms what Alex is saying.
regards
Right; I said the same thing. If the shroud length is constant; the amount of stretch required is the same. But you can't apply this universally to all shrouds because different boats have different lengths of rigging wire. If you plug in 4000 mm for your base length; the delta L will double to get the proper tension. Since that's true you can't use the 1mm/5% rule to get exact tension. If I tighten an intermediate 1/4" shroud using that rule the tension will likely be ~40-50% of breaking load because the shroud lenth is much shorter than the upper shroud; which goes from the masthead to the deck.
Giu-
I'll get back to you with the data; I am aboard my boat tonight using a different computer. I should still have the spreadsheat I was doing the calc's on; but if not I will make up a new one. I was just using the modulus for 316 stainless and an approximate breaking strength for each size. Please don't use those numbers I posted as "actual"; I was only trying to make the point that stretch is also dependent on wire length (and this is independent of the max strength of each wire diameter).
