Thread: Hints and tips
Old 04-27-2008
Boasun's Avatar
Boasun Boasun is offline
Boasun will become famous soon enoughBoasun will become famous soon enough
Work up a "Pre-Departure Check Off List" and one for "Pre-Arrival." Thus you can be sure if all that needs to be done is completed before to doing either one.
That is if you use the lists.
Check your engine both ahead and astern, before you get underway and before you make your approach to the pier. Have had engines stuck in forward and astern when I had to get underway and when making a landing. It does make for interesting times when that happens.
