SailNet Community - View Single Post - Acetone or Mineral spirits?
post #9 of Old 04-30-2008
DrB
Just Clarification
Acetone ((CH3)2O) is chemically very different than Xylene, isopropylbezene,and Naptha. Acetone (and MEK and Cyclohexanone) are ketones, the others you mentioned are alkenes or in the case of Naptha a mixture of alkenes and alkanes. Acetone and MEK are low boiling very fast evaporting, were as the others are not.
I still advocate using water/soap as the initial process for getting rid of the bulk sanding dust/dirt, then following it with a solvent wipe (acetone or similar) for spot greasy or oily areas, then your paint prep fluid the whole, and lastly the topcoat paint.
DrB
DrB is offline
