Counter Tops
Go to your local Home depot or Lowes hardware outlet and ask for a Porter Cable or makitia trim router with removeable base.If you can use a 3/8 router bit with ballbearing follower. You can realy route by hand with this setup. Prefit the lam before you glue,by the way did I mention to use 1/4" dowels to position the lam on the top and remove them a couple at a time to keep the lam in place. Just finished the counters in the head this week, the galley top is next although I think I might just use some extra solidsurface I have Good Luck with the Project My trim came off rather easily after the screws were removed a putty knife works well, don''t force it take yopur time and all will be well in the end
