  #12 (permalink)
Old 05-03-2008
Idiens's Avatar
Idiens Idiens is offline
Larus Marinus
Idiens is on a distinguished road
Originally Posted by mauidan15 View Post
A couple of weeks ago I was out and the engine started to rev down, ramped back up for a while and then down again and just shut off. A little bit of white smoke came out and that's about it. Since then I've removed and cleaned out the fuel tank. Polished the fuel and have bleed the fuel system out, changed the fuel filter a couple of times. I've pretty well determined it's not a fuel issue. When I go to start the boat it turns over strong but never catches a spark like it's actually going to start. Guessing its possibly a compression problem? The engine is a 3GM Yanmar. Any suggestions apprieciated.
If you have got all the air out of the fuel system (no bubbles, just diesel, coming out when you loosen the pipe junction to the injectors and turn the engine over) I would start checking elsewhere before pulling injectors.
One thing to check is that the exhaust system is not blocked. If you have been turning the engine over without it firing, for more than a few seconds, and have not closed the raw water inlet stop ****, then you may be close to serious trouble. The raw water ends up in the exhaust and if it back-fills to enter a cylinder, that is really bad news. Depending on the exhaust system, it depends how best to empty the residual water out and check for a clear blow through.
In any case, close the raw water inlet before turning the engine any more - until it runs again.
Jonathan-Livingston
