SailNet Community - View Single Post - Yanmar Heat Exchanger Problem?
post #2 of Old 05-03-2008
Faster
A number of things come to mind...
Your water line to the mixing elbow may have come adrift...
Water pump failed (possible overheating)
Heat exchanger plugged badly, as you suspect.
Not sure what you mean by "no exhaust either" - while engine was still running??? Inside the boat was hot, was it fumey too? Could you smell exhaust gases down there?Is the exhaust hose from the water lift to the outlet intact?
Sounds nasty....
Faster is online now
