The primary cause of this is a bent centreboard caused by grounding. The next most common cause is heavy growth of barnacles, etc. If it is bent it is not easy to fix. It may cost you more than the boat. If it is just crusty and stuck in the trunk then it's not too hard to fix it.
The cable is not a big deal.
Good Luck
