SailNet Community - View Single Post - Deck hardware
Thread: Deck hardware
post #6 of Old 07-25-2003
mikehoyt
mikehoyt's Avatar
Deck hardware
Then there is the quicker less permanent method. Use 3M 4200 to fill in old holes and seal the new ones. This is assuming that you are replacing with a similar block in the same location. Use fast cure and it will be fully set in 24 hrs and you can probably use it in 12.
Mike
mikehoyt is offline
