Old 07-28-2003
mikehoyt's Avatar
mikehoyt mikehoyt is offline
mikehoyt is on a distinguished road
Whisker Pole Fittings
What size pole and boat do you have?
If it is the 6-12'' pole or the smaller one then it is easy and cheap.
In that case you can just cit off teh last inch of pole with a hacksaw and epoxy the new fitting in place. I did that successfully when one of my ends broke.
If you have a much larger pole then the end fittings are much more expensive and it is worth the bother of fixing the current in place end.
My 2 cents
Mike
