SailNet Community - View Single Post - How tight is too tight?
post #5 of Old 05-06-2008 Thread Starter
Guess I missed the boat in wording my question. What I meant to ask was can you split a hull by too much tension? Can you tension a line with the buckles more than a full sail will? In the past I was worried that maybe the rig might come down if there was too much stress on the lines, but never that the hull could split. On my boat the chainplates are considerably smaller than what the hull joint is and should give first in a contest. The Tartan chainplates must be the strongest point in the whole boat.
I am not an engineer, but when I heard the company response that the rigging was too tight I had questions. Is it actually possible to pull the hull joint apart without the rigging or chainplates themselves failing first, or is the hull joint that weak in a normal boat.
dwightgry is offline
