Hello,
As Sailingdog wrote, you want to keep a flooded battery at 100% charge as much as possible. You NEVER want to deeply discharge the battery.
As others wrote, I bet you are not properly charging your battery. Do you have a voltmeter? If not, get one and learn to use it to measure your battery. If you find the voltage is above 12.2 or so volts, the charging is not sufficient.
Good luck,
Barry
