Old 05-06-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Henry-
If you use the VHF for any transmission, it's going to draw down the batteries fairly quickly, since they're at least 25 Watts of transmission power, and somewhat inefficient, so you're probably looking at 2.25 or 2.5 amps per hour for transmit.
You're also missing the parasitic discharge that wet-cells go through, just sitting there...
It could be from overcharging, but I seriously doubt it. What PWM charge controller are you using, and is it a three-stage charge controller. If it isn't a three stage charge controller, you need to get one that supports bulk, absorption and float phases at a minimum. If it was overcharging, it would probably be boiling off electrolyte. Have you checked the electrolyte specific gravity and levels in the cells on a regular basis??
Are there any other parasitic loads on the batteries that may not have been accounted for???
If you're new to the Sailnet Forums... please read this POST.
