jjns-
Most boats are going to change shape a bit when floating, as opposed to when sitting on stands, since the weight is distributed differently, and the presence of water will affect the way the hull distorts.
Make sure your bilge pumps work and the batteries are topped off... to take care of the inevitable water that does get in until you have the seal adjusted properly.
If it was red locktite, it will need to be heated to be loosened as a general rule. Using blue locktite, instead of neverseez is probably a good idea.
