I thought the PSS bellows tension is set by positioning the opposing PSS rotor on the shaft as specified in the instructions. Is that the adjustment you are referring to? Isn't the shaft alignment pretty much unrelated? And isn't the shaft alignment pretty much determined by installing it through the cutlass bearing (whether it's in strut or stern tube)? Are you referring to engine mount alignment adjustment? If so, how will that sink the boat?
