SailNet Community - View Single Post - Removing Monitor Wind Vane Steering
post #2 of Old 07-30-2003
tahitisail
"V" out the holes using a countersink bit or a larger bit.
Use some "Bondo", if you like use the more expensive MARINE FILLER and search around to get some with a hardener close to the color of your hull. Cut off the excess bondo with a sharp wood chisel and sand it smooth with a fairly fine sandpaper, being careful not to mess up the finish on the surounding area.
tahitisail is offline
