SailNet Community - View Single Post - Yanmar 1GM10 won't start
post #4 of Old 05-08-2008
BarryL
BarryL's Avatar
Hello,
Can you turn the engine over with a socket at the end of the flyweel? I don't want to be the bearer of bad news, but if a new starter and a new battery won't spin the engine you may have a serious problem....
Of course, the starter could be bad, or not installed properly, or you may have a wiring problem. If you do have a wiring problem between the start switch and the starter, changing batteries and starters won't solve the problem.
At this point there are too many variables for me to really offer meaningful assistance.
If this were my engine I would manually turn the engine with a socket on the flywheel and the decompression lever set. If you can spin the engine, then check power to the starter. As a test you can use a jumper cable from a fresh battery right to the starter. If that spins the engine then you have a switch or wiring problem.
Good luck,
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
