SailNet Community - View Single Post - Yanmar 1GM10 won't start
post #5 of Old 05-08-2008
Faster
Hopefully you didn't try to start it last fall for an extended time with the sea water **** open... if you did, the engine may be hydro-locked (and may have sat full of water all winter)
If, as Barry above suggests, you can hand crank the moter, then with luck all you have is a voltage issue...
Faster is offline
